AJ_720 »
https://forums.nicoclub.com/aj-720-u241752.html
Thu Sep 18, 2014 8:57 pm
If you pull back the rubber on the switch/connector you are talking about, you can pull that apart and that is how you remove the fuel pump. As I recall, you can pull it apart with force and it didn't have any clip or anything. Do not pull on the wires as they are part of the pump itself.
When I just installed a new fuel pump (Carter OEM model) on my 720 about a week ago, I noticed it didn't come with the plug connector like the one you have in the picture. All I had to do was connect the white (positive) wires together and bolt the black (negative) wire down tight underneath one of the bolts on the frame. Just saying in case you have a fuel pump that does not have the connector .. it is not necessary.
Hope that helps!
