Fuel pump removal 95 240sx
nizmo569
Car: Datsun 510
need a basic guide to removing my fuel pump. tried the search engine but didnt find anything on a 1995. Thanks!
180fan
Car: 89 fastback
under your back seats you'll see the fuel pump stuff.
nizmo569
Car: Datsun 510
OK I found the plate and removed the four screws, and then the 3 hoses and pulled out that assembly. now im looking inside the tank. I can see the fuel pump at the bottom but how do i remove it?
onosqv
Car: '92 240sx Vert
you gotta reach in there and pull it out... it's sort of clipped on. Hope the fuel tank is decently low. I believe it's like an up and left (toward driver side) unclipping action, but should be fairly easy.
You should be able to get at it thru the trunk, that's how I removed my buddy's...
nizmo569
Car: Datsun 510
I got itout no problem and i replaced the fuel pump and im getting ready to put it back in but i noticed that the 2 wires going to the pump unit the + one had a boot over it and the replacemnet pump didnt come with one. with both the + and - exposed inside the tank is this going to pose any danger? Gas...electricity....boom?
onosqv
Car: '92 240sx Vert
haha, won't be a problem. Gas has properties so taht this doesn't happen (i think it's like good conductor of electricity or something or other)... think about it, your fuel pump is completely submerged (and has been) in the fuel tank when it is full - boot or not, gas is gettin in.
It actually takes quite a bit of energy to get that to spark.
180fan
Car: 89 fastback
It's not hollywood so don't sweat it. The boom comes from the gasoline vapors and a spark.
nizmo569
Car: Datsun 510
where can i find the fuel pump relay. and any other related fuses
onosqv
Car: '92 240sx Vert
nizmo569 wrote:where can i find the fuel pump relay. and any other related fuses
passenger side fuse box in the engine bay... if you pop your hood, it's pretty hard to miss ... you seriously should invest in getting a factory service manual... or at least d/ling one...
