fuel pump relay
nm240sx
Car: 90 nissan 240sx
ok so i got my sr20det ecu chipped. they said now all i need to do is get the nismo fpr and get a relay to my walbro fuel pump so i can put 12volts to the pump... so i ordered the fpr but as for the relay, HOW DO I WIRE THAT UP?? they said the pump doesnt really get the 12 volts it needs so i need to put a relay to it with 12volts...so how do i do it? how do i wire it up?? can anyone help or show me a diagram?
Emperor_Tha
This is from the top of my head. Sorry no picture, iphone is my only Internet supplierI did this setup. It eliminated fuel cut but it kill my pump in 3weeks 1.5k miles since I dd my carWent back to stock
Relay triminal1. 32. 4
Use fuse on the wire1 is 12v ignition key on2 is ground3 is 12v striaght from the battery4 is wire to the pump + if fuse pop switch 2 and 3d
Modified by Emperor_Tha at 7:20 PM 11/5/2008
nm240sx
thank you very much! right now its runnin like a pro! but i was told not to horse beat it till i do those 2 things.. thanks for responding
