duffman1278 wrote:Hey luis what is the issue with your car?Right now I'm looking for my fuel pump relay because I am not getting any fuel sent to the injectors but the fuel pump works.
Has the engine ran before in your car? If not, you might find the problem in the interface harness with a mis-pinned wire. I had the same problem, fuel pump worked but wouldn't turn on when the car was switched to on. Find the relay, pull it and check with a volt meter to find the constant, switched and signal wires(there should be 4 or 5 wires into that relay). The Signal wire should give power to the relay when the car is switched on, constant and switched, well that's self explanatory, there should also be 1 ground and the lead going to the FP. Jump the lead to the FP and the constant and see if the FP turns on. If so, there might be a mis-pinned wire...
Goodluck
On the S14 the FP relay is behind the driver's side kick panel, mounted with 2 other relays closest to the door.
