Fuel Pump relay location?
A home for 1983–1989 300ZX owners!
Glorywagon
Car: 1985 300ZX turbo
1985 300zx turbo fuel pump not working . Where is the relay or breaker,fuse at. I have been looking at the Chilton's manual and didn't find it. Thank You Danny
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Chilton's manual sucks. Throw it out. Buy the Haynes manual.
Also, not everything is in those cheap repair manuals. GO LOOK AT YOUR CAR.
Open the passenger door.Look in the door jamb right next to the seatback.Remove that little plastic vent.Look inside.You SHOULD see a blue relay right there.
Glorywagon
Found that but I also have no fire to the engine when Itry and start it. thanks Danny
Glorywagon
Chilton's manual sucks. Throw it out. Buy the Haynes manual________________________________________________
I did the wife went to get me a Haynes manuel. And I do look at the car but it didn't say look behind this panel to find the fuel pump relay. But thanks to you I know now. Thanks friend Danny
PS you thank it could be the security system that has shut everything down?
Modified by Glorywagon at 3:28 PM 11/8/2008
AZ-ZBum
Stock alarm will only prevent the starter from turning the engine over. Won't prevent the car from running.
Glorywagon
didn't want to hear that thanks
sharjt
Car: '06 G35 Sedan 6MT
'83 Datsun 280zx turbo - RIP
No Fuel pump and No Spark usually means the ECU is bad. I've had this exact problem on three different Zs. Changed out the Ecu and it fired Right up.
Return to “300ZX (Z31) Forum”
