Fuel Pump Relay Issues :P RB26 300zx
aero1310
Car: 90 300zx with rb26 swap
Alright Im doing a Rb26 swap in a 1990 300zx. The fuel pump relay wont switch on, pin 18 on the ecu is hooked up correctly. Did a voltage test on pin 18 and is only reading .05 volts when I turn the key. When we jump the relay the pump will turn on. Anyone have this issue? How much voltage is pin 18 suppose to put out? Is there any other wire I can splice the b/p wire into to make it work? Searched all over for answers cant find anything...also posted on rbz32.com but that forum is pretty much dead...
The engine cranks over and I get power to the AEM ECU... pretty much stumped at this point
Krazykouki
Just hard wire it in, problem solved. I hate chasing down voltage issues.
Ramius83
Car: 1995 240sx SE
According to the wiring diagram, the ECU at pin # 18 supplies a ground to the fuel pump relay. Looking at the bottom of the fuel pump relay connector. Terminal 1 is to ECU terminal 18. Terminal 2 is power from the ignition switch. Terminal 3 is battery source, which in this case is the ignition switch. Terminal 5 is to the fuel pump itself.
Terminals 1 and 2 are the coil, 3 and 5 are the switch. So when you wire it correctly or maybe you have a bad relay, everything should work fine. If not, bypass it.
FYI, Nissan ECUs mainly supply a ground to relays/switches as the ground side of ther circuit "arcs" less when energized.
aero1310
is there a ground wire coming out of the ecu that the 18 would circuit to?
mp3
Car: 1990 nissan 240
I'm not sure where the fuel pump is in that car but I had the same issue with my 240 I just cut the ground wire right by the plug made my own grounds the added an after market relay
aero1310
just hooked up the stock ecu, heard the pump spin like a mofo so turns out its the aem :( calling them tomorrow, hopefully i can get it repaired...
aero1310
nm call me an idiot but I did not know you have to upload the calibration files first lol maybe I should read directions
tay-fu300zxtt
Car: 300zxtt,
My rb26 swapped 300zxtt fuel pump comes on when I hook the battery up..
I'm using the haltech..I wonder if I have a similar issue..
