EnthusiastMan »
https://forums.nicoclub.com/enthusiastman-u60438.html
Sat Mar 24, 2007 7:30 am
Update: I've found where the black/pink wire runs. Apparantly somewhere in the ECU harness the wire changes from black/pink to black/yellow. However, I have another dillema. When I hook my voltmeter to the black/yellow wire at the ECU and turn the key on, I get battery voltage. When I ground this wire out it kicks the fuel pump on. I know this is the way it's supposed to work but when I ground the wire out the fuel pump keeps running and doesn't stop. Normally they are suppose to run for 3-5 secs and then shut off. Also, if the ECU is providing battery voltage to this wire, what is supposed to ground it? I thought that the ECU would ground it because it's only supposed to be grounded for 3-5secs. This is very confusing.
