Check out FEB ROTM for a few pistures etc of my Patrol with turboed VH45. http://www.nicoclub.com/ROTM/rotmfeb09.shtmlOrphan wrote:Got pics of the set up? My father has a patrol and the engine is on the way out with 340,000km's ha.
I've been watching this with interest. A bit scary considering I've gone the VH for better reliability than the TB42 (constant head issues). Fortunately the cut I got has very low K's (87,000) but I guess time will tell. The beauty of the VH is they are cheaper to replace than the TB42 and it's only the initial conversion expense that hurts. If it lets go, I should be able to pick up another for under a grand.darinz wrote:
Have you been following the threads on bearings? See quite a few of us are having issues so maybe something to think about as well.
Thanks! I learn something new everyday...Mettler wrote:Nah a surge tank is typically in the boot (though you can run it anywhere), its purpose is simply to remain filled to the top with fuel so that under hard cornering conditions, there is never a loss of fuel supply to the main pump due to sloshing.
The pump in the actual tank just keeps the surge tank full, and when it's full it cycles back into the fuel tank.
100kgs lighter and more power than a TB can't hurt either though!!!The handling difference going from the TD to the VH was pretty amazing. But you will need lighter front springs as well.As an idea, I run 135psi in my bumpstops where as the guys with TD's are running over 200psi!!!!_XLR8_ wrote:
