http://zilvia.net/f/tech-talk/....html
1.How do you test a fuel pump? I can't start car because fuel pump does not operate. I measured zero volts between ground and the black/yellow wire in connector right at fuel pump . I did this test within first 5 seconds of ignition coming on. can i just hook fuel pump up to 12v source directly and see if it starts?
2. Where is the darn fuel pump relay? is it in the front corner(passenger side) of engine compartment next to battery? I see a small black rectangular(1in by 2.5in by 4 in) container there which contains two plugs with small wires. no labels. i assume this is the eccs and fuel pump relay?doesn't look like normal relay. do these two relays come as one unit if you replace them?
Modified by vancouverbc at 7:41 PM 9/7/2008
