Postby
Plattq45 »
https://forums.nicoclub.com/plattq45-u18941.htmlFri Aug 13, 2004 10:34 am
i just took out my fuel pump, and i did a 12volt test on the pumpi can feel the vibration but couldn't feel any air being pump? is that normal or my pump is gone?
Postby
DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.htmlFri Aug 13, 2004 10:34 am
There are cheaper non-factory parts of course, and most will work just fine...for a while. The risk of having to buy another part and do the job again within a couple years is too high IMO. Aftermarket parts have a bad reputation for a reason. Honestly I'm very surprised yours died so soon and without tell-tale signs.
Postby
maxnix »
https://forums.nicoclub.com/maxnix-u127.htmlFri Aug 13, 2004 10:34 am
Very few FY33 fuel pumps for 1997-2001 Q45 on this board have ever had to be replaced. Check (and steam clean) the tank while you are at it. Get a new filter also. Something must have contaminated your fuel for it to fail so soon.
Postby
Q451990 »
https://forums.nicoclub.com/q451990-u142.htmlFri Aug 13, 2004 10:34 am
maxnix wrote:Very few FY33 fuel pumps for 1997-2001 Q45 on this board have ever had to be replaced. Check (and steam clean) the tank while you are at it. Get a new filter also. Something must have contaminated your fuel for it to fail so soon.
This brings up a new question... if the FY33 pump is a multispeed setup, what sort of output does it have? Could it be a more reliable updated replacement for the G50 series? Maybe if paired with it's own updated (protected) FPCU?
