maxnix wrote:The pump is not silent and varies speed in 3 stages based on demand.
Useless to compare to previous unit until it is all buttoned up. If it is new OEM, it is as quiet as it will ever be.
Good job, and be glad you probably saved stress on your FPCM.
I had to put my hand on the new OEM pump to make sure it was on
The old one you could here from outside the car.However under WOT you can here it if you turn off the tunes and listen REAL Hard and you sit in the back seat.
But who sits in the back seat of there Q45 anyway?
