moso wrote: but i believe the IACV also uses that hot lead.
the air reg solenoid uses that hot lead.
if you want to relay that ish. at the fuel pump plug
blk/yellow is ignblk and/or blk/white is ground
the green/bluered/blkdepending on 1st or 2nd gen s13 they go to your fuel level gauge and low fuel warning light in your gauge cluster
i would just take the two black wires from that harness, put them together and ground them back there. then for the blk/yellow wire use a relay to boost amperage and trigger.
ive just rewired a few of these cars from scratch. not even painless wiring, scratch
