onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Dec 29, 2006 10:49 pm
If you are running direct power to the pump, then you are bypassing the relay - and since you mentioned your pump doesn't go even w/ direct power, the pump needs replacing.
To find out if the relay is supplying power, you can use a voltimeter on the positive wire going to the pump to see if it's getting voltage. If you aren't getting voltage to the pump, then you need to check the relay... which, unfortunately, I don't know where it is located off the top of my head.
You may also want to check the fuel pump fuse, which is in the engine bay.
