ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Sat Jan 21, 2006 4:54 pm
94 Q45T, 160K miles, fuel pump has been "humming" since we bought the car.
My wife was driving the car home tonight, she stopped at a red light and the car stalled, the engine would crank but every time she tried to give it gas it would stall, I went to where they were stranded and planned on trying to jump the fuel pump control plug wire to ground as I read on here. Not even sure if I had the right control unit, I removed the bulkhead cover and this modeule was just to the right of the fuel pump, the wire harness from the fuel pump/tank "tee'd" off to this module. Wasn't sure which pin to connect to ground, so I checked for power at the plug with a test light, every time I connected the test light to one of the pins I would hear a click and lose power until she turned the key off and on again, Also noticed in this plug and on the corresponding pin on the module that they looked burnt. Checked all the fuses in the car all were good. Disconnected the plug to the fuel pump and than plugged it back in, Went under the hood and squeezed the fuel line coming from the fuel filter trying to see if I could feel fuel going thru the hose, had my wife try to start the car and all of a sudden it started and ran fine all the way home??????????? Fuel level was at about 1/4.
Is it possible that due to the fuel level being so low that the fuel pump got too hot and just needed to cool down, and after sitting for about 35 minutes it finally was able to start again?
I need some help with this I Know I need the fuel pump ( OEM or aftermarket does it matter?) but I don't want to just start replacing parts that I may not need. Thanks
