jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Wed Nov 09, 2005 1:56 pm
there was no need for wiring trimming or whatever on this pump (like the walboro units)? because one time the wires i crimped together with the required crimp plugs got loose so i resoldered them for ultimate security.
make sure the amp for the fuel pump is either 10a if its OEM replacement (or match, etc.) or 15a for aftermarket (especially important if you have an SR).
when you turn the key to accessory and u dont hear the pump whine or suck for a couple of seconds, then something is deathly wrong.
get back to me with what kinda motor you have and ill attempt to source you some diagrams. anyway, good luck!
