DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Jan 27, 2003 12:13 pm
Did you actually measure the voltage? It'll tell you 2 things: 1) as Maxnix said, whether the wires are colored correctly (polarity), and 2) whether the pump is getting enough voltage. Should be around 5.5-6V at idle, if I recall correctly. Did you notice any burn marks or melting on the connectors between the pump and the controller? I think worst case, you're looking at a bad controller (~$380), but I'm hoping to eliminate every other (cheaper) possibility before throwing parts at the problem.
