benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Sun Feb 20, 2005 7:29 am
Chris isn't saying the relay is bad. What he's saying is that only two of those four wires at the relay should have power. As in - wiring problem perhaps.
One wire should read 12v (for the relay coil)
One wire should read 0v for a couple of seconds after you turn the key to on (this is the signal from the ecm, if Chris is correct about that)
One wire should read 12v (for the power to the fuel pump)
One wire should go back to the fuel pump, and I couldn't say what random readings it may give...
These readings should be taken with the relay disconnected.
Report back your findings and we'll go from there.
Oh, and does the relay click when you first turn the key on by chance? That would have been the first and easiest test.
Modified by benemorius at 12:03 PM 2/20/2005
