240ShaneX »
https://forums.nicoclub.com/240shanex-u127219.html
Mon Oct 03, 2011 8:40 am
Hey guys, I am having problems with my car starting and think it might be my fuel pump. Hopefully you can help! If I try to start the car (hot or cold) it will just crank and crank 7+ seconds before starting. Now if I prime it by turning it to on, back to off, then back on then start, it usually starts right up. I checked the fuel pressure with the engine off and it was about 33psi the first prime, then 39 the second prime (normal spec is about 42 with no vacuum). When I started the car it dropped to about 36psi. Now, once the car's started, it revs smooth and strong with no hesitation. I replaced the fuel filter just to see if that was it, but no difference. This kinda leads me to think its not the pump since it runs so good after its started, but then why would it need to be primed to start? Thanks for any advice!!!
