It's been a bad month for the J..
OK, I think it's the transmission but if I describe it hopefully you other guys can verify.When cruising at a steady speed that puts me in the 2800-3000 rpm range like highway speeds the J starts to putter like it's running out of gas. It doesn't do it drastically and honestly the only reason I probably noticed it is because my louder exhaust exagerates engine noises...which is a good thing for diagnosis.
Feels like it's running out of gas but not on such a severe level. I think either it's the TC engaging and disengaging rapidly at that speed or the fuel pump is randomly failing. I can hear my fuel pump in the morning on first start, but it's not as loud and dramatic as what failing fuel pump owners describe. More of a high pitched whine that most people might not even notice. Both are due to fail now at 120K+ miles. I only got it to duplicate the feeling once this morning on the way to work, so maybe it's just the beginning. I'm more likely to get the problem fixed before I"m on the side of the road, but need to know if I should be bracing for a 3-digit dollar fix or a 4-digit.
oh yeah, I only run chevron premium and had a transmission pan drop and fill at the beginning of this year.
