Zilverado »
https://forums.nicoclub.com/zilverado-u38750.html
Wed May 24, 2006 8:24 am
Check your fusible link(s)...
These are wires that are designed to "burn" (similar to a fuse) to protect the wiring system from overload.
If you trace the positive (+) cable from the battery, you should find a fusible link in this wire - usually quite near the battery. If the link is burned, replace it. If it happens again, you likely have a short somewhere.
Other than this, check for bad connections - - including the main grounding cables (engine block to vehicle frame, etc.).
Let us know what you find.
