fuel pump or bad sensor?
cornuts
Car: 91 nissan 240sx
so my car is trippin so here are the simtoms, ill turn the car on and it sounds like a subaru and ill have to rev past 3000rpm so it can clear up and it dose. ill start to driving for a lil bit it then it dose it agian (like a subaru) and no power no nothing, i rev it past 3500rpm and it clears up so i dont know whats going on? (i thought fuel pump but i hear it on) sensor maybe any advice
johnny5
Car: 91 red 240 hatch
my car was doin this, sounds like an injector is going out or your not getting spark, heres now to tell:
1. start the car2. pull plug wire 1, see if theres a difference, if so replace the wire and keep going through 2-4, 3. once you find the plug that doesnt make the car bog, push the wire back onto the plug and pull the corresponding plug off the dist, hold it close to the hole and see if theres a spark, if theres spark you know its fuel, if there isnt you know theres no spark.4 take off your ful rail, place paper under each injector and turn the car over, just a lil5 look at the papers, see if theres 4 small circles, if not then you know where your not getting fuel6 if there is then go back to that plug that didnt make the difference in the motor( ie the way it sounds will change and itll shake more thats what i mean by difference) pull that plug and see if its sparking
that should be it but if you find that that plug has spark it just means its a soft spark and you need to do a tune up. ie plugs wires cap rotor and fuel filter for good measure
undead310
did this solve the problem?
cornuts
actually i took off all my emissions and its alot better!!! but still from 2500 to 3100 its still a lil lazy but mid to top rpm the power band is great.. still drifts pretty good, i guess because the rpm is allways above 3100
cornuts
o i forgot to tell, i noticed somthing funny a week ago. mind you my interior is stripped so i can here my fuel pump working, anywho it was getting late so i turned on my head lights and i heard my fuel pump get quite so i turned my lights off and on and i can really hear a power drain.. dose any body notice this? is it normal? would i need the alternator upgrade...
