OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Tue Jun 12, 2012 9:04 pm
With the ignition on spin the CAS by hand, you should hear the fuel pump cycle, and injectors click. If that does not do it check power to the CAS two of the outer pins are power and you should see battery voltage, if you have it chances are the CAS is bad.... Just diagnoses this issue on a SR swap last night.
