fuel pump not turning on in my ka-t
DisFrikkenWill
well yesterday i installed a walbro fuel pump in my ka24de-t and started up my car and it ran better then when it had the stock fuel pump. we shut the car off thinking everything is fine. we install a electronic fuel pressure gauge, tapped in the middle where the fuel filter and fuel lines that goes to the fuel rail. then started up the car and it ran fine....we revved it a little and the car sputtered and died out. we tried starting it again a couple times but it wouldnt start. we checked all the relays,fuses, uninstalled the fuel pump like 5 times, we even put back the stock one to see if it would work but still it doesnt. we even tested both fuel pumps stock and the walbro on a battery and they both work fine. what do you think happened? what could it be....the car ran fine for 2 days after my t25 install untill the gauge part. wich is wierd. everything seems fine. when i turn the key to the on position the fuel pump doesnt turn on. we even installed a NEW fuel pump relay and still it doesnt work. when we touch the ecu wire # for the fuel pump relay with a test light and ground it to the car the fuel pump turns on like it should when the key is in the on position and when we turn the key in the off position it goes off like how it should. like the ECU or something isnt getting enough ground? cause how the fuel pump works it goes like this?.....from ecu--->relay---->fuel pump? i was looking at this also but it says for s14 only and i have an s13. http://www.ka-t.org/walbrorewire.php i dunno though would that even help? i really need help please, thanks!
