i pulled out the fuel pump from the car to check it independently. i left the pump submerged in gasoline and connected the wires to an extra battery i had and it squirted gas. at least i know the fuel pump is still working. any ideas would help.
Sorry to threadjack here, but could you explain this a little more OM3GA? My s13 has had both of those problems since the day I got it. Exactly what diode gets burned out? Is it in the ECU or elsewhere?OM3GA wrote:Hooking up your MAF wiring wrong is the number one cause of frying ecus. Typically you fry the Ignition switch circuit. I have seen two things happen from it. Sometimes it cuts power to the fuel pump and ignition coil/Ignitor etc. usually by frying the main engine fuse. Other times it fries the diode that allows the power to be cut which means the engine stays running even if you turn the key off and pull it out.
Definitely hardwire your fuel pump and the Deatschwerks kit is definitely the simplest and cleanest. Glad to hear you have got something going.
