Fuel pump not priming
DubsSuck
Car: s13 hatch
What tells the fule pump to prime?
ANVIL
Car: RB25DET S13.5
theres a relay in the under hood fusebox by the battery. also a fuse in there
DubsSuck
Car: s13 hatch
we checked them with a multimetor, they are fine
ANVIL
Car: RB25DET S13.5
well if you have a muitimeter, then you can check continuity of the pump. unplug the harness and on the fuel pump side of the harness check the power terminal continuity to the ground terminal. if you dont get any continuity then the pump itself is bad.
if the pump is good, the relay is good and the fuse is good, then u have a wiring issue
ANVIL
Car: RB25DET S13.5
and to answer ur original question, the ignition circuit when turned ON position sends a signal to the fuel pump relay to prime for 5 seconds.
DubsSuck
Car: s13 hatch
odd thing is.. i don't even think the ecu is getting power
DubsSuck
Car: s13 hatch
I guess i have a wiring issue.. but everything is pluged in where its suppoesed to be. wich leads me to belivie that the ecu isn't getting power cause along with the fuel pump not priming the coil isn't shooting a spark. and there is nothing wrong with the coil.
DubsSuck
Car: s13 hatch
ANVIL wrote:and to answer ur original question, the ignition circuit when turned ON position sends a signal to the fuel pump relay to prime for 5 seconds.
we checked the EGI pump relay, im pretty sure they are the same thing. anyway.. theres nothing wrong with it
DubsSuck
Car: s13 hatch
its kinda hard to work on your car in the drive way when its snowing...
ANVIL
Car: RB25DET S13.5
sounds like u have a bigger problem. try checking the big alternator fuse.
DubsSuck
Car: s13 hatch
where is that one at
ANVIL
Car: RB25DET S13.5
same fusebox its a 75A i THINK, something high like that, a big square fuse
DubsSuck
Car: s13 hatch
oh a fuseble link?
ANVIL
Car: RB25DET S13.5
no but you can check that too. im talking about the big alternator fuse, read the fusebox cover
DubsSuck
Car: s13 hatch
oh ok i found it.. i didn't get to check it tho.. its kinda hard to pull out
DubsSuck
Car: s13 hatch
alternator fuse is finewhere is the fuseable link is it the white wire coming off of the battery post?
DubsSuck
Car: s13 hatch
I Need an Ingnition switch!!!
