melik2004 »
https://forums.nicoclub.com/melik2004-u182156.html
Tue Apr 05, 2011 11:29 am
thanks for the welcome: i checked voltage at the connector that would go to the fuel pump and it is 12v and stays on for 4-5 secs during futile crankin, then turns off as it should if there is no ignition. furthermore, i hear the faint hum of the fuel pump for the five seconds through gas tank filler with a hose to the ear. I need to check fuel pressure at the rail.. do you know of a picture which shows the testing port? any other ideas? from what i gleaned, the 97-2001 are different. BTW, if i'm getting voltage at the fuel pump connector, doesn't that mean the relay, module, and fuel pump control module is working? thanks, lived in columbia for a while, back while..
