Fuel Pump Making noise
240Knightrider
My fuel pump has been making a noise lately. Kinda like a (theres power to it noise-if that makes sense) not it filling up though....
It does it and continues for a little bit after I shut the car off. It does go away, but its getting louder.
My first guess being its going bad..and I more than likely just need to replace it.What do you guys think
Thanks!
KATwo40
Car: 1993 240sx KA-T
Yup. The increasing audible noise is characteristic of a pump on it's way out.
Just buy a Walbro 255 for $80 and put it in there. Then, you already have a high flow upgraded pump for future mods that might warrant the extra flow.
240Knightrider
Cool, thanks for the confirm
Crazy how its still cheaper than the ones at parts stores for OEM
s13rb25det
Car: 92 240sx w/rb25det
wont a walbro 255 overpower the stock fpr causing a rich condition in the engine? just wondering
240crawler
Car: 1991 240sx
s13rb25det wrote:wont a walbro 255 overpower the stock fpr causing a rich condition in the engine? just wondering
Yes, mine has been making the noise for 2 weeks. I am also interested in finding out if the high flow pump will cause my black smoker to be worse.
KATwo40
Shouldn't cause an issue, since the system is not a "deadhead" system (meaning whatever fuel is not sprayed through the injectors is recirculated to the fuel tank).
However, some Hondas with recirculating systems have been known to suffer a rich condition when running a high flow pump, as opposed to stock. I suspect a failing FPR (maybe a pinhole in the diaphragm) is the cause. I hardly see how the higher flow capability would pose a threat.
Anyone else with solid data on this subject, rather than my speculation?
240Knightrider
I just searched it
Some have had problems.
Most convincing was the guy that said he didnt have any problems and still doesnt three years later.
I think it just does depend on FPR and its condition/
sleepyRPS13
Car: to sleep
my teacher said if the fuel pump is that noisey, its about to die! dum dum dum.
is your car hard to start?
240Knightrider
No its not hard to start, its been doing it for about a month now.
ive also been told about the relay maybe going bad...
