wa-chiss »
https://forums.nicoclub.com/wa-chiss-u37545.html
Sun Sep 10, 2017 7:39 pm
I put the Denso 320LPH pump in and she started. However, it ran rough. REALLY rough. I got the idle to stabilize enough to check which cylinder(s) were misfiring. Got to #2 plug wire, no change in idle when I removed it. Managed to get the car to work the next day (2 mile drive). I swapped the pump for a factory pump just to eliminate that possibility, still no change. Checked the spark plug, fouled. Cleaned the plug and retried, still misfire on 2. Change the plug, still a misfire. Take the injector out and supply power and ground, no click. Check another injector, audible click. The injectors have over 200,000mi on them so I decided to swap all 4 with new units. The engine actually runs GREAT now.
I'm debating on swapping the 320LPH pump back in.
