fuel pump location on 98 altima
General discussion area for the L30-chassis Altima
donna
Car: 98 nissan altima
do you have to drop tank to get to the fuel pump or what?
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
i am 98% sure, that for the fuel pump on that car just remove the fuel tank straps, drop the tank , on top of the tank there will be a retaining ring on top of the tank which hold in the fuel pump module, turn the ring counter clockwise about 1/8 turn, and the whole module should then be able to come out, the pump will be on the end of the module, swap it out along with the strainer and reverse the procedure for the reinstall,
careful with all the hoses as to not kink any
Scandinavian Flick
welcome to nico by the way
blackd21vg30de
Car: 1993 Hardbody, 1999 altima se
please dont do what he said,,, remove the two bolts holding the back seat in, take it out under the seat is an access panel. under it is the top of the tank and fuel pump all nice and easy to get to, dont spill gas in your car!!! you would have to drop the whole rear suspension to drop that tank!!! I have a99 so I know its under there.
Return to “2nd Generation Altima Sedan (1998-2001)”
