Stripes »
https://forums.nicoclub.com/stripes-u76540.html
Tue Nov 18, 2008 5:00 pm
This is a lot to read but I really need your help. Thanks!
Okay so here's the deal. I've got a 93 hatch that I swapped a notch top SR20 into. After I completed the swap and went to start it up the fuel pump was not priming or running at all. So I couldn't figure out why. Relay was good, fuse was good, and there was no wiring involved with the fuse box that I had to splice or anything so I didn't see how that could be the problem. Anyway, I ended up finding that the fuel pump relay ground wire wasn't getting a complete circuit somewhere down the line, so I cut it and grounded it to the chassis and installed a switch so I control when the pump runs. I don't know why it didn't work before and I can not find any wiring schematics involving those wires. If anyone knows that would be awesome.
Problem #2; I've got Sard 550cc injectors with a stock ecu, stock fuel rail and fpr. When I start my car I have to keep on the gas constantly to keep it running and it will not let me rev past 3k. Seemed like a MAF and/or timing issue to me, so I took the MAF off to see if it would make a difference and I still had to keep on the gas to keep it from stalling but it let me rev up to 4k. So then I talked to Brian at MA motor sports and some other people and they all said it could be a MAF issue but there is no way my motor will run properly being un-tuned with 550cc injectors and that is my main problem. The thing is at one point I had my motor idling perfect at 800rpm, so I don't get why it wont do that now.Anyway, I've been told that in order to get it steadily running I will need an aftermarket fuel pressure regulator and something to tune my motor with.
So I'm getting a D-Jetro Power FC and I am wondering if I can write my own air fuel map to get a close enough tune to make my car run steadily. I would just get it tuned at a shop right away but it costs more than what I've got so I figured I could do my own sort of a base tune and then get a shop to fine tune it to perfect everything.
Again, thanks for taking the time to read all of this and I appreciate your help. Thanks!
