Damien89 »
https://forums.nicoclub.com/damien89-u210332.html
Thu Mar 13, 2014 11:01 am
I replaced the lime green relay located in the right rear of the trunk. The events leading up to this we're as follows:
Thursday, began to put a little while leaving the grocery to store. Then it cut off. The fuel pump wasn't on then (I notice after multiple attempts to crank it). I call the tow truck, and about 45 min it fired up as if nothing odd had just happened.
Friday, drove to work and back with no problem.
Monday, the same is true
Tuesday, when u went to crank it(before work) nothing. The same thing when I realized that the fuel pump wasn't on initially.
