Fuel Pump Install Issues
Clyons0203
Car: SLK55, Talon TSi, G35, Q45
135k G50 with a humming pump. I took out the old put in a used pump i bought off this forum. The pump turns on, I can hear it pumping. But car doesnt start. Not even a hiccup. Just turns over and over and over.
Is it flooded???? Will the alarm cut out ignition if it goes off??? I need help asap
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Used pump?
You just bought someone elses problem.
What is the fuel pressure?
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:Used pump? What is the fuel pressure?
Brian is correct. You need to tee in to the fuel line with a pressure gage downstream of the fuel filter and measure fuel pressure for a few seconds after turning the ignition on (while you hear the fuel pump running) and while engaging the starter (trying to start the engine). IIRC, it should be in the 40psi range.
Clyons0203
Yeah hopefully I can get my money back.
The pump sounds good. It whirrs and doesnt buzz, but no gas is being pumped. I T'd into the fuel house off the fuel filter, no gas, not even a drop. so the pump sounds good but its pumping ****.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Clyons0203 wrote:Yeah hopefully I can get my money back.
Speaking of the fuel filter... did you or didn't you?
