Fuel pump?? Injectors??
Crautz240
Car: 92 240sx Hatch
Alright guys i need a little help.. whenever i let the car sit for a bit after i have driven it when i go to start it up again it seems like the engine is choking runs really rough and dies. Te only way to keep it goin is by stepping on the gas all the way till it finally stops running weird and can idle. Even then while i drive it at low rpms it runs rough and it seems like the flow of fuel to the engine is not even. Could the fuel pump be crapping out and not giving my motor a steady flow of fuel or are the injectors clogged... or is it even fuel related?? I have searched for cars with related issues but they never say if they figured it out
Crautz240
Car: 92 240sx Hatch
bump!!
Razi
Car: Moo
Pour in some Gumout Regane in your fuel tank and drive it around, and if your injectors are clogged, it should clean em out.
ZOMG.SR20
Car: 1990 s13
buy a new fuel pump in and also change out your distributor same thing happened to me it took me 6 months to figure it out
