Fuel pump Ground??
newdude1
Anyone know where the fuel pump ground is located at on a 90 S13?
Wretched
Car: 93' Hatch
newdude1
I already looked at that. But that doesnt tell you where the ground itself is located at.
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
on the pump or the body???
Wretched
Car: 93' Hatch
most likely it's on the body behind the rear panels...just follow the black wire.
crakin
ok here is what I found... I'll link to it, just in case. Look for the black-yellow wire leaving the fuel pump. It should be going to an air reg solenoid. then from the solenoid a solid blk wire should be going to ground. Also, a blk-pink leaving the pump goes to your relay....GL
http://www.240edge.com/manuals...2.pdf
look on pg.4 upper right hand corner for your pump diagram.
