That's exactly what happened to my car, and it'll happen more often later. Car shakes really bad if it's #4 injector(radiator side).wmdavis007 wrote:It's just weird...the sputtering and sluggishness won't go away until I shut the motor off and restart it...then it may not come back for 45 minutes. And it's never happened until I've been driving for at least 15 mins.
Update on my problem:Well my car has been sitting in my driveway for about a month and a half. I haven't had much time to work on my car between work and fixing up my house. My problem changed from being an intermittent one to being a constant one. It's missing on the #4 cylinder all the time now. I've checked about everything I can think of and now I'm thinking my ECU is bad. What I've done up to now: first I pulled the plug wires while the motor was running and I found that when I pull #4 wire there was no change in the motor but with the others the motor would almost stall. I then took #3 wire and put it on #4 and put #4 on #3 and the #4 cylinder still was missing...so I know it's not the wires. I pulled the dist. cap and rotor and they look normal. The plugs look nice...slight brownish color...no oil or wet plugs. I did pull the #4 fuel injector and replaced it with a working used one, with new o-rings, and it's still missing. After running the motor for a little bit I pulled the #4 plug and it's got fuel on it so I know the injector is spraying. I have an extra 5-speed ECU...but...well, I can't find it...lol. I left it at my buddies shop when we did the 5-speed swap and he packed it up and put it in storage, now we can't find it...so I just bought one online. Damn I hope this works cause I can't stand not driving my vert. Plus I'm driving my 06 Expedition and it takes twice the gas to drive to work as my 240. I should get the ECU early next week so I'm keeping my fingers crossed this fixes my problem.94_240sx wrote:I was very frustrated when it happened first cuz it was doing this random crap, but after the first one it was easy second and third.
Will do. I'm hoping my ECU that I ordered gets here in the next day or two. I'll post my findings soon as it comes in.PsyckoDrifter wrote:I've been having the EXACT same problem with my 93 Fastback. When I turn it off and turn it back on it runs fine for up to 45 min. Please let us know what was wrong if you figure it out because I'm tired of having no torque.
Sounds just like what mine was doing for a few months...but now it misses on 4 always. My ECU hasn't come in yet so unless it comes in tomorrow I may not get it until next week . Hopefully this will fix my problem...if not I'll have to take it to my buddies shop and just put more time and money to find the problem.PsyckoDrifter wrote:Okay so today I got up and drove it to work and it didnt sputter AT ALL. I'm so confused.
