Fuel Pump Gas Mileage Question and Maximum Pressure for 370 injectors
justjuiceit4
Car: 1993 Nissan 240SXs, (Coupe and Convertible) 1994 Infiniti Q45
I am eventually going to go turbo, but for now I am going to start with the basic components. I plan to run the Walbro 255lph hi pressure pump, I have read that as long as stock pressure is maintained that the car will not run richer and I will retain stock mileage. Is this true? Also, what is the maximum pressure that 370 injectors can handle before failure? Thanks.
NISTECH
if your worried about gas milage I would suggest not increasing the performance of the car as you will regret it later on. As far as you question I have no idea what the threshold is , just offering you advise based on your statement.
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
This question is better asked in the forced induction or car specific forums.
But the answer is no, the walbro does not increase the fuel pressure.. it just allows the fuel flow to go to a higher level. It will work on a stock car fine.
the injector question depends on the motor. if it's a ka24de like mine, it will be fine at about 10 psi. It can flow for more on the KA24DE at stock pressure, but you're balancing on the edge of a knife at that point.
s13sr20chris
i have heard of big fuel pumps overwhelming the stock regulators though mine did not. nissan side feed injectors are still reliable over 60psi. the new top feeds prob more.
s13sr20chris
btwmy sr20det s13 ran 12's and got over 25mpg running rich with me beating on it hard every day.
justjuiceit4
PMan_S13 wrote:This question is better asked in the forced induction or car specific forums.
Did you mean 10 psi above stock pressure or 100 psi?
