Fuel Pump fuse
SR20S14
What does this fuse look like? I have a 1996 240sx se, i dotn have any fuse panel information for my car..can nebody help me out?
BadMojo
Car: 2007 Mazdaspeed 3
Perhaps this changed from the S13 to S14, but the fuel pump fuse on my car is in the plastic box near the battery. The cover over the fuses conveniently lists what each fuse is for. One of them says fuel pump. If you don't have anything that looks like this then...err...don't mind me.
I've got no clue if this is the same on an S14.
BTW, on my DOHC S13, it's a 15amp fuse, I believe.
Hijacker
Car: '92 240sx Convertible
'94 F-150
all the fuses were condensed to a larger fuse box in the S14. It should be on the left hand bank of small fuses. It will be the third one from the bottom and is a 15amp fuse.
hope that helps
SR20S14
thanx for the help, I will try it out in the morning
entity
The fuel pump fuse is in the inside fuse box, near the drivers side left foot.
