SQUIRREL78 »
https://forums.nicoclub.com/squirrel78-u118716.html
Wed Oct 29, 2008 6:43 pm
This started when I had my car parked out in the street, I went out to put the car in the drive way. I turned the car on and it cranked but it didn't want to start until i pressed the gas some more. It started, I put the car in the drive way later on I tried to start it, it only cranked but no start. Fuel pump fuse was popped, I replaced it. The fuel pump works. I checked if any thing was loose, still nothing got enough gas in the car. Could the fuel pump relay be the cause of it? If so I can't find it I checked under the hood. I'm guessing it might need a new distribitor rotor or the fuel filter could be clogged.
