turbo_dreams »
https://forums.nicoclub.com/turbo-dreams-u24859.html
Sun Aug 26, 2007 7:52 pm
Well...about August 10th i was coming home and it was raining real hard (don't know if that has any significance with my dilema) and then my car starts to starve of fuel and kept cutting off and coming back till i slammed it to see if it got an feul...it did, then, completley died...so after a few minutes i see my fuel pump 10 amp fuse blew...so, i replace it and go home, no problem for the next few days...and then yesterday i go to the beach and on the highway same thing happens, no fuel being sent to motor...so i pull over and replace the fuse n keep driving, and then...again...and again...and again, about 12 fuses blown n then next thing i know a tow truck pulls up n says he was ordered to get me off the highway...so 140 dollers later my car's in my garage...and a wise friend of mine told me this is a well known problem on 240's, that the wires from the feul pump get corroded during the years, specifcally the blue and white one...so he suggested i unclip the clip by the fuel pump with the wires...cut the clip, clean the wire, and then extend it a tad and soder them and ditch the clip...he also suggested a new fuel pump...
Fast forward to Saturday Night....
Alright, so my friend and I swapped the fuel pump a for a Walbro 255 Saturday night. Pretty simple. The wires for the fuel pump, just cut crimped them and then heat shrinked it. Put everything back together, and primed it a few times. Then Started it. Ran fine, I took it around the block, then he did. Ran fine. No problems. Then about 45 minutes later, we decided to go get some chinese 3 blocks away. Drive there, park up wait 15 minutes for the food. Got it, hopped in drove off, then a block later, it blew the fuse. We put a new on in, Blew on the next block. Then we checked the fuse again, changed it, started up, and when he put it in gear it blew. 30 minutes later (1am) we come back to the car, pull the pump assembly back out, everything's fine. Changed the Engine Control Fuse cause that blew too aswell as the Fuel pump fuse. Same ****. Haven't cut the clips for the fuel pump off yet, gonna do that later.
Very frustrated over it. Need to pick someone's brain on it.
Sorry for the long post.
