fuel pump fuse location?
onecrazyfoo4u
Car: 03 Type S
Like it says, I know it's not under the hood, already checked. I don't have a fuse box cover for the driver side kick panel, so I have no clue what fuse is what. Anybody have a picture of the fuse box cover or can anybody tell me where it is? thanks alot!
SpeedRacer1
Car: 1990 240SX, G35
The fuel pump fuse is in the under the hood fusebox.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
in my s14 its in the cockpit. theres 2 rows up and down, on the left, very bottom, 3rd one up, blue one, take it out, if its it when you turn the key you wont hear the fuel pump on.
onecrazyfoo4u
Car: 03 Type S
Yeah it's wierd, I finally found out where it was. Same spot as you said, 3rd one up, a blue 15amp one....so I pulled it and turned the car on and it ran just fine. I ran it for about a minute, it never died...I thought it was supposed to run outa fuel and die. Anyways, I went ahead and change the fuel filter and pump anyways, it lost a bit of fuel but no problems at all! Thanks all.
jr_ss
Car: 95' S14
Next time, just pull the relay. If it's an S13 I believe it's under the hood? If it's a Zenki 14 then is in the driver's side footwell.
onecrazyfoo4u
Car: 03 Type S
Yeah I have a 95, but pulling the fuse didn't do a damn thing. The relays next to the fuse box on the drivers side then? I say a few relay looking things, i think 2 with blue covers and one with yellow maybe. Which one is it....just for future reference? Thanks man.
jr_ss
Car: 95' S14
I believe that it's the one closest to the door in that group of 3. It should be a blue relay and have 2 black/yellow wires coming/going to that relay..
