fuel pump fuse keeps blowing
afmafia
hi i have an s13 blacktop my fuel pump fuse keeps on blowing i have a walbro 255 fuel pump . what can be the problem
SpeedRacer1
Car: 1990 240SX, G35
Assuming its installed right, up it to a 20A fuse.
quiksilvia
Car: 95 s14 se
i had the same problem, the pump worked fine with the ka then with my redtop it kept blowing the fuse, check the amp of the ka fuse box for the fuel pump, if it matches then find the short
afmafia
its seems weird but it only does it when im like at a 1/4 of a tank when tank is full its fine
yellow_jacket
Car: 95 240sx
When you are at a quarter tank the fuel pump is no longer completely covered with fuel and can get hot. As electrical connections get hot, they build resistance, and then pull more power. You may want to pull the pump and check all the connections.
