Locknut »
https://forums.nicoclub.com/locknut-u35423.html
Fri Nov 10, 2006 10:23 am
Had all sorts of weird intermittent starting problems...thought it was the injectors cause I had good pressure to the rail...but lost it overnight. Thought it was the fuel pressure regulator...but I hear they usually don't go bad. Replaced the fuel pump 20k ago (car has 110K)...so didn't think that was the problem, no humming, no noise. Then disaster...dead Q and expensive tow....jumping the pump to ground wouldn't work! Supposedly it's a fried controller AND bad relay. BIG question....would the relay and the FPCM go all at once? Should I pop for a new fuel pump just in case. Why else would the FPCM or the relay go bad? Anyway I can test the fuel pump? Would Ohming (.5 spec) be enough? If so...I'm not quite sure which pins on the blue connector to check?
