fuel pump for y33
Qproject
is this a common replacement part ? should I replace it ? it has 128,000 miles.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
fuel pumps dont seem to go out on Y33 as much as G50, probably less strain on it due to using only 270cc injectors vs 370.
Q45tech
In 97 they redesigned the FPCU plus they added a safety resistor from fuel pump to ground so that if FPCU failed the pump would still run enough to crank and cruise................problems show up as weak acceleration [fuel pressure drop].
