eazye2000 »
https://forums.nicoclub.com/eazye2000-u30064.html
Mon Nov 05, 2007 5:02 pm
You will be just fine with a Walbro in your car. I had a walbro in my car with the stock FPR and only saw about 2psi more than stock at idle.(about a needles width on the gauge)The fuel pump WILL pull more than the factory fuse, that's for damn sure. BUT, only if it's trying to create tons of pressure. Like if you have an adjustable FPR and have it cranking the pressure. Keep that in mind when/if you upgrade your car later on. Put a relay on it, and put some fat nasty wire on it directly to the battery for best results. Or do it anyways, it wont hurt.
Forgot to add, that you can get a Walbro 255 HP for like 85$ with install kit from Marty at Injected Performance. They are a site sponsor, and a great company to deal with.
Modified by eazye2000 at 12:59 AM 11/6/2007
