Initial test of my repaired controller showed low pump voltage at idle. Oscilloscope showed a poor jittery 20kHz PWM waveform applied to the pump. Replaced C8, C9 (1nF) to fix - they get any FET drain spikes so will be under stress.
For my own amusement I internally bridged pin 7 to pin 5, and added a 1nF SMD across R20 to assist cleaning up the battery feedback signal, and used 100pF 1kV ceramic SMDs for C8, C9 to offset the larger FETs I'd used (C8, C9 are FET drain-gate added capacitance to slow down the switching transitions).
The control circuit uses PWM at 20kHz to regulate the pump voltage, based on the two control inputs from the ECU. Pin 1 held low (0V) will force idle pump voltage. Pin 1 floating and Pin 2 held low will force medium pump voltage. Pins 1 and 2 floating will cause full battery voltage across pump.
Ciao, Tim
"anyone with a personal gun for protection should be shot". I don't know who said it, but
