silkysmoothyjud »
https://forums.nicoclub.com/silkysmoothyjud-u50966.html
Sun Jul 29, 2007 9:30 pm
Can bad injectors cause a bad pump, or is it the other way around? Chicken or the egg. I believe Nissan fuel systems just go bad randomly. I had two injectors fail, one right after the other, then the fuel pump started to hum. Cause and effect? I thought so at first, but I still had cream colored injectors in my car. 5,6,7,8 were purple (I am one lucky used Q owner). I changed 1234, they are all purple now. Bad ignition coils cause a rough idle and non-OEM injecotrs will cause problems as well. The whole motor will noticeably vibrate and you will have a hard time finding which one is doing it without color. If your injectors do not have dots they might be botch (bosch are purple too). and they freakin suuuuuuuuuuuuuuuuuuuuuck!!!! botch will cause a rough idle when ac is on, hesitation when the car is cold, bogged down performance all together.....
