ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Sat Feb 04, 2006 12:28 pm
I took the car for a drive today (first time driving the car) with the FPCM connected, leaving my subdivision I checked to see if I could powerbrake the car (which it normally won't do), I was able to easily break the tires loose, going down the road the car took it's time to get up to speed as it normally does.
I went down a deserted street nearby and pulled over, I unplugged the FPCM and hooked the terminal to ground and started to drive home, at first take off the car acted normally but once it started rolling it felt like a different car, RPM's climbed fast and steady, and once it shifted into high gear and I hit the gas it downshifted quick and smooth, no problems getting home and car ran like I think it should.
Could this mean that the car is not getting enough gas when the FPCM is connected but unplugging the FPCM and letting the fuel pump run at high speed allowed it to get all the gas it needed which in turn caused it to run better?
Would running the fuel pump at the high speed when taking off from a stop cause to much fuel to get to the engine thereby loading it up? And if it was loading up would that cause it to still run like crap from a stop?
Thanks
