krayton wrote:
they use fuel sumps. basically a little container. your in-tank pump fills it up and just circulates back in. you then have your 2 outlets near the bottom going to inline boschs. then returns to the fuel sump.
so imagine a container with 2 basic inlet/outlet for your stock pump. then 2 outlets to dual pumps, and a return. i got a lil diagram on other cpu ill upload when i get on it
Hey can you post that diagram up I don't get what your trying to say.
Are you talking about a Surge tank/Swirl Pot?
He can just run them in parallel to a Y adapter/connector to a single line.Or he can run two lines to the front to each side of a 3 port rail.
