Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Sun Oct 24, 2004 5:26 am
This is regarding a friend's 1990 Q45 with 145k.
I sold my rebuilt 1992 FPCU to him on eBay (rewired per Tangalora's method). I tested it for 100 miles prior to putting it up for auction, and it worked perfectly. But he continues to have starting problems. I'll paste his e-mail below:
Quote »Jesda:
Again, thank you very much for your help.
We bought the Q45 in 1996 when it had 75,000 miles on it. From the paperworkI received from the Infiniti dealership, the fuel pump had not been replacedwithin this 75,000 miles.
The fuel pump has been making a humming noise which I can hear from thefront seat almost since we purchased the car. A couple of years after wepurchased the car the electrical connection (I now think I can identify itas the ground connection - the same one which looks burnt on the rebuiltfuel pump control unit you sent me) on the fuel pump control module and thesame one on the harness looked burnt and the Infiniti dealer installed a newharness and it worked well with no more burning signs from then on.However, I later had to replace a fuel pump control module and it lastedabout 1 year and 8,000 miles. and then I replaced the fuel pump controlmodule a second time and it lasted 3 years and 25,000 miles. Now I am upto the present date when I purchased your rebuilt one.
The possible key is that I don't think the fuel pump was replaced before Ipurchased it in 1996 and I know it has not been replaced after I bought it.It presently has about 145,000 miles on it.
The only electrical tool I have is one of those 12 volt screwdriver devicesthat has a light in it to see if there is current. I know I have current tothe fuse for the fuel pump. I held the fuel pump relay (the lime greenrelay located near the antenna) and felt it click when my wife turned on/offthe car. The fuel pump used to make a clear discernible hum when I turnedon the car and know there is absolutely no noise indicating the fuel pump ison.
There is no gas coming from the fuel pump. Is there a method in which I cantell:1) the fuel pump is receiving voltage?2) whether or not the fuel pump is definitely bad?
I wanted to post on the forum you suggested, and I registered to do so, butI have not received the password yet. I was instructed they would send mypassword to my email address. That was a very helpful forum.
Thank you very much
David[/quote]Quote »Jesda:
Another comment, my gut feeling is that voltage is not getting to the fuelpump and the fuel pump may not be bad. I feel this way because I hearabsolutely no sound from it and my 12 volt electrical tester picks up nocurrent in the fuel pump relay (although I do feel it click) the harnessesboth to the fuel pump control unit and fuel pump. Could it be a short or aground wire?
Thanks
Thank you very much for your help.
This is what I have done:1) - Based on what I read in the forum, with the fuel system otherwisecompletely intact, I filed an alligator clip's teeth so that it fit into thesmall female tab on the bottom left (terminal side, with the clip up) of thewhitefuel pump control unit harness connector (this is the terminal which hadbeen burnt prior to you having the fuel pump control module being rebuilt).I connected the other side of the wire to a ground. My wife turned on theignition while I was in the trunk. I heard a one second low volume noise(like someone clapping their hands almost silently) and I felt somethingever so slightly move inside the fuel pump for a second (my hand was on topof the fuel pump). There were no other noises or movements.
I then returned inside my house and read your email. I then applied thealligator clips to the ground of the fuel pump and a ground on the car. Iheard the same noise which I heard when I grounded the female tab on thebottom left of the fuel pump control unit harness. Nothing else occurred.
Does this give you information to diagnosis the problem? I know believevoltage is going to the fuel pump or else it would not have made the onesecond noise and one second feeling that something moved. Is this a correctimpression?
Do you think this provides reason enough to conclude it is a bad fuel pump?I read the forum about fuel pumps and they cost $250.00. I read one shouldonly buy an Infiniti fuel pump. However, I must be economically driven, sois a pump from a salvage yard or a new off-brand from Autozone a second-bestalternative?
Thank you again for your help.
David[/quote]
Modified by Jesda at 10:51 AM 10/24/2004
