Haha, ok! Let´s say it´s a KA (to be in the right forum), I´m building an E85 engine and need to double the fuel side to be on the safe side.Aiming for 6-700bhp and need a pump able to feed around 1200 horses on gas.WDRacing wrote:It would help to know what the project is? I had an article where a Mustang owner used dual 255LPH pumps and was laying down just over 900 at the wheels. SO two or 3 255LPH pumps should definitly do the trick. Plus that particular pump doesn't get very hot.
Why in tank? You better explain the project, you can't just mention 1200 HP and leave us hanging!!!
Yeah, looked at both SX and Aeromotive today but no in-tank ones.IWannaS15 wrote:Take a look at some high hp drag cars to see what they run. I remember seeing the Apex R33 in a magazine and it had a good description of its fuel setup.
My guess is they use dual in-tank pumps or an inline pump. Companies like Aeromotive make some high hp fuel pumps, but I think theyre all inline pumps.
Yeah, same with methanol but they often talk about 100% ethanol and all the rules around dry alcohol.WDRacing wrote:Mike, I was reading about E85 awhile back. They recommed an external pump do the corrosive nater of the ethonal. Whats your opinion on this?
I know but I need the size to know if I can use them, come on WD, call one of your contacts and ask for the diameter... You would be my hero for 2007!WDRacing wrote:2 or 3 255LPH pumps will be your best bet in my opinion if in tank is the way you're going.
Here's a site that lists them for $85 255 LPH Pump
I only got a 70 mm hole and I need to know the diameter before I order. I can´t fit two if they are 36 mm each.WDRacing wrote:Man I looked all over doe the dimensions...I didn't find crap. Whats exactly are you worried about?
